transmission swap
transmission swap
i have a 84 berlinetta with 5 speed..thinking about putting a th-350 soon.is this a pretty easy task?what does the torque arm mount to on a th-350?would i need a new transmission crossmember?would i have to have a driveshaft made?if anyone else knows anything please let me know
im not sure about the torque arm mounting...might wanna check out www.spohn.net i think is the address. im sure ull have to change the crossmember and spohn might have a driveshaft for ur swap,but dont hold me to that.
hope that helps
hope that helps
there is a conversion kit that u have to buy i bought one when i did my swap and that is about it the driveshaft is the same size as long as u get the long tail th350 if u get the short tail u will need a different drive shaft. i might sell my conversion kit i havent really thought about it yet i am doing a swap to a t5. i will look and see how much it cost me fot the conversion kit itz not more then 150 i dont think.
carguyshu
01-22-2017 11:19 AM
