Turn signal question
Just this morning i turned on my right signal and it didn't flash green like normal. I could still hear it though. I checked outside the car and all my blinkers work fine any ideas as to if its just a bulb i have to replace or what?
There is a small bulb that is burned out behind there. And it isn't the hardest thing to replace, but it is to get to. Lots of dash parts to remove and alot of trouble for only one bulb. I say just let it go till the other burns out. Unless it bugs you that much!
-Rabid
-Rabid
I just went through the same thing with my IROC . I took the front covers off and pulled the bulb out with a needle nose pliers. Actually the bulb wasn't blown , the bulbs holder must have had a bad contact because when I wiggled the bulb it started to work .
Good luck
Dan
Good luck
Dan
stangspank
11-13-2015 01:02 PM
formula79
26
08-05-2002 12:21 PM
Darth Xed
13
07-22-2002 12:45 PM
CMJ917-95CMO
06-19-2002 09:10 PM
