underdive pully set
Old 05-27-2003, 01:24 PM
slayer6x6's Avatar
underdive pully set
ive heard up to 15 hp can be gained with this mod. with this pully set can you feel that much of a difference, if so than is there any brands that you would recommend?
slayer6x6 is offline
Old 05-27-2003, 01:51 PM
87DJP2001's Avatar
This subject has been covered number of times with Pro & Con. For starters Do Not BELIVE the Mfg claims of that much HP. Also on a street car you will have problems with the the charging system which I can do without.
So do a search or just wait for the Posts.
87DJP2001 is offline
Old 05-28-2003, 11:43 AM
1badIROC's Avatar
I got a kit about six months back when they pulley on my harmonic balancer came off in the middle of I-5, leaving me w/ no cooling, power steering, etc. Scared sh*tless, but anyway. . .
I noticed a good gain. I wouldn't say 15-20 horses like they advertise, but probably a good 7-10 RWHP. It was a lot easier to smoke the tires.
I say go for it. Fairly cheap, but a b*tch to put on if the bolt on your alternator is frozen.
1badIROC is offline
Old 05-28-2003, 01:11 PM
Screamin95's Avatar
will cause prob with charging system. used to have them in my t/a
and the computer never had the voltage it needed.
Screamin95 is offline
Old 05-28-2003, 01:20 PM
slayer6x6's Avatar
would a higher amp alt. solve this charging problem? maybe a 140 amp?
Old 05-28-2003, 05:44 PM
TheGreatJ's Avatar
It wouldn't help much, because the alternator doesn't hit it's peak current output until it gets above a certain speed, and the whole problem with underdrive pulleys is that they slow the alternator down which means it hits peak output at a higher RPM. The minimum speed is the same no matter what the output rating. It'll help a little because the extra charging when it's above min. speed will offset the loss of charging while below min. speed, but it's not likely to be enough to keep the battery topped up.
TheGreatJ is offline
Old 05-28-2003, 05:49 PM
camarocruzin's Avatar
i got a set and i've been running them for about 2 weeks, nothing negative, seems to wind up a little faster, nothing insane though.
camarocruzin is offline
Old 05-29-2003, 02:19 PM
slayer6x6's Avatar
i seen a set on ebay for pretty cheap so i think im gonna go for it, i do alot of highway driving to school every day so maybe that will help a little bit. when i put them on ill let you know how it goes. thanks for all the replies
Old 05-29-2003, 03:51 PM
91RS5speed's Avatar
I have march 3 piece set for about 10 months now and have had no charging problems.
91RS5speed is offline
Old 05-29-2003, 09:04 PM
slayer6x6's Avatar
im gonna get the alt. and crank pully. whats the third one, the water pump?
Old 05-29-2003, 10:00 PM
TheGreatJ's Avatar
Power steering usually.....
Old 05-30-2003, 12:27 AM
Nitromethane's Avatar
Dropped 0.15 seconds in my ET, no charging problems other than the fact that my battery is toast anyway, I'll be replacing that shortly, ran the underdrive pulleys for about 6 months - make friends with a guy who has an auto shop and an impact gun to do your alternator pulley. March Perf. also have a set that retains charging ability if charging is an issue for you, but I have an 800w RMS stereo system in the back of my car n I have no problems with an OEM reman pep boys alternator, unless its night, i have my headlights on, sitting at a red light wtih the stereo turned up to max - my subs cut out, but it did that before the pulleys anyway, I don't even run a cap lol I should get one of those one day.
Nitromethane is offline
Old 05-30-2003, 01:34 PM
slayer6x6's Avatar
is there any other pulleys that you can get besides the crank, alt, and ps pump?
Old 05-30-2003, 01:55 PM
87DJP2001's Avatar
How many more do you want??
Old 05-30-2003, 07:01 PM
Water pump for increased cooling.
Quick Reply: underdive pully set
