Underdrive? Pulley Setup?
I was wondering about this March pulley set up
http://store.summitracing.com/partde...=KeywordSearch
should I go underdrive if I have a lot of 12v hookups, big system, l.e.ds, sat. receiver and cd player, start switch, tach and gauges galore, or will it drain the alt too much.
If not then I was wondering about this complete set up
will this fit on a stock 350 tpi 1991 camaro, just bolt it on and go? and will the power steering pump from a 91 camaro fit on this kit, it says saginaw p/s pump???? Or what do you guys think I should do for a pulley set up for a 91 z28?? any suggestions?
