V8/v6 T-5???
V8/v6 T-5???
As I've already posted, I got a LT1 that I'm puttin in my '89. Is there any major difference in the T-5 they put in the 3.4/3.8 cars vs. the 305 cars of the 80's and early 90's? Any help would be great!
Re: V8/v6 T-5???
The newwer 3.8L T5s have a removable bellhousing, so you can prolly get one that will bolt up to a sbc
- Justin
Re: V8/v6 T-5???
Don't waste your time with a V6 T-5. Different bell housing, 10 spline input shaft instead of 26 spline, and weaker internals. Get a World Class T-5 and you'll be alright. Mine has held up to a 400+ hp LT4 for almost 4 years now.
Re: V8/v6 T-5???
Having said that, if you HAVE to get your car running using a V6 T5, you can, but it won't last long.
If you use a 10 spline T5 behind a v8, you will need a v8 bellhousing, a v8 pressure plate, and a v6 disk. Otherwise, it all fits.
Local pick your part has a 90 day money back guarantee. I have gone through about 5 V6 T5s, and none of them lasted longer then 90 days. So I just kept getting my money back and buying anotherone. Worked good, but weak.
Re: V8/v6 T-5???
I have a 92 with a V8 mill and a non-world class V6 T5 that has already run 12.56 @109 in the 1/4 with a 100 shot and slicks. There is no difference in the stringth of the internals only minor gear ratio changes. And the only difference in the world class and non-world class is the type of bearings and the syncros. As far as the case of the T5s the late V6 trans has a Ford style bolt patern where it bolts up to the bell housing so that part will not work with the V8 bell housing. now as far as the input shaft is conserned the is a company that will make coustom shafts to convert V6 to V8, V8 to V6, or what ever mix match combo you can come up with for about $100. Thats the route I'm going to go with now that I am putting a more powerfull mill in the car.
P.S. I just put new syncros in the trans and the gears looked as good as when I first put the trans in the car after numerous trips to the track, and about nine months on the street.
Re: V8/v6 T-5???
two words for you...g-force. They rebuild solid t-5's that hold ungodly amounts of hp...but it comes with a price. They've held up to 900+ HP mustangs and the internals are the same. Good Luck
Chris
Chris
Re: V8/v6 T-5???
Originally Posted by IgorT.455/406
I've broken lots of T5s, including two world class, don't waste your money on T5s and go with a T56 or a Tremec.
Re: V8/v6 T-5???
Chris
Chris
Wouldn't spend the money on one. You're still plagued with the weak case of the T-5. If I were going to spend the money for a G-Force T-5, I'd get something like a Richmond or a T-56.
Re: V8/v6 T-5???
And I bet you were either powershifting them or had way too much power for a T-5 anyway.
I mostly had issues with the thrid gear, as the cluster shaft is 1pc. cast with all the gears, and thrid is big/skinny, so any flex in the case (big deal with T5s), and stuff can/does brake. I also broke the case once as well (v6 t5). IF you drive a T5 easy, it will last some time, but....
I've had friends with lots of power in their mustangs running low 11s on nitrous and no problems, but....I also had friends running low 14s with their mustangs brake the T5. However, you stick the low 11s guy in that 14s Mustang, and it goes from low 14s to high 15s....goes to show you driver makes a big difference in T5 life.
I also used my car as a TRUE daily driver, went everywhere, holidays, to/from work, etc, etc. That makes a difference too.
Re: V8/v6 T-5???
I power shifted mine too. The car was also turning 1.7 60 Ft. times and damn near pulling the front wheels at the same time. I also have a friend that had a non world class T5 running 10.20's at the track for 3 years with no problems. the main problem people have with the T5s is when they put them in heavy cars. And yes my car was a daily driver that I put over 10,000 miles a year on.
Re: V8/v6 T-5???
SWEET...So a T-5 with a LT1 isn't such a bad idea? I'll stick with a V8 T-5 if I do it (still can't stomach the $1300-$2000 asking price for a T56! ). If I buy a T-5 and rebuild it (beef it up), what is the best source for parts and info regarding this? Thanks!
Re: V8/v6 T-5???
Edit: Im putting down about 370 and i beat the **** out of mine..i drive it as hard as i can..im trying to break it..
Re: V8/v6 T-5???
To be honest, with my extensive experience of T5 brakeage, and seeing what my freinds have done to their ford T5s, I would have to say if this G-force kit comes with a STRONG countershaft, chances are it will hold. Like I said, the biggest problem I had was the thrid gear braking. Mostly due to the fact that the coutershaft (or cluster shaft) is 1pc. cast, and stock junk is very weak. IF this problem is fixed, 85% of T5s weakness is fixed. So......
Anyone got a link to this G-force deal, I wanna check it out. What about the price? Do you need to supply a core? Thanks.
Re: V8/v6 T-5???
heres the link http://www.gforcetransmissions.com/tran_gt-5.asp
they use hi grade nickle for materials not chinesium like borg warner did...
there a little pricey, but there isnt another tranny out there that will hold what these will...there 600hp rating is based on a 4,200 pound car, they did this because there are a lot of guys in old muscle cars buying these...so naturally a 3,200 pound car (mustang) can put a lot more power through it
Re: V8/v6 T-5???
