Valve Cover Leak
Old 05-29-2004, 04:02 PM
  #16
MY91Y84's Avatar
dont forget leaky valve seals lol
MY91Y84 is offline
Old 05-30-2004, 10:05 PM
  #17
Scales's Avatar
I had a similar problem with my centerbolt covers leaking. They didn't wanna seat with the bigger roller rockers on. Since my heads accepted both designs, I just bought a nice set of perimeter covers (with rubber gaskets) and that did the trick. Now the only little leak I have is a mystery. Every now and then I would get a little splash of oil that I saw on the top of the valve cover (pass side) and a little on the header. I can only think dipstick tube, but I put a factory replacement in, so I don't know why that would be the problem... Can't think of anything else around there that would be able to squirt on top of the valve cover like that... Any ideas guys??
Sorry to hijack, but it seemed a similar problem...
Scales is offline
Old 05-31-2004, 12:04 AM
  #18
aklim's Avatar
What head? What rocker? I am using AFR centerbolt heads with 1.6 ratio RR and they are the crane gold narrow ones with no problems with it seating
aklim is offline
Old 05-31-2004, 12:13 AM
  #19
Scales's Avatar
I'm running Dart Iron Eagle heads with Comp Cam Pro Magnium 1.6 roller rockers. The clearance was questionable from the get go as these rockers weren't made to work with centerbolt covers. They were actually a second coice after the GMPP 1.6 RR were hitting the retaining ring on the spring. The guy helping me with my upgrade (Max 93) read that if you bend or trim the braces inside the covers, they might work. I guess mine were the accpetion... But after seeing the new covers on there, it really made the motor!! Just wish I knew where that "splash up" was coming from so I can finally get my car back on the road and have this project complete!!!
Scales is offline
HectorM52
07-30-2017 11:46 AM
HectorM52
01-30-2015 11:34 PM
ModdedNerd
01-29-2015 07:23 PM
BIGCOWL-IMP
12-19-2014 06:59 AM
thenewkid
11-29-2014 04:54 PM
Quick Reply: Valve Cover Leak
