votec intake torque specs
iam going ot install a spdc vortec tpi intake on my motor but can not find the specs to torque it down at, i see that if iam using the factory plastic intake gaskets its 11lbs but iam using fel-pro 1255 fiber ones and iam sure its higher then the 11lbs, any help would be great, thanx
Re: votec intake torque specs
Back before GM incorporated the steel washers in the gaskets to prevent gasket warpage, I used Fel-Pro because they used it. 11ft/lbs is what I used, and I've never had a comeback.
carguyshu
01-22-2017 11:19 AM
CARiD
01-27-2015 06:27 AM
