Were exactly does the TPI sticker go on the back bummper?
The reson im asking cause I just got mine back from the body shop. Someone ran into the back and i had to get the bummper repainted. They stuck the tuned port injection sticker all the way to the left. I though there was supose to be a 3+ inch space. Like on the right side were the emblem is. It's going back cause it's not right. There are still spider webs in the bummper which they charged me more to to get rid of.
Pictures of orginal cars that have not been painted would be great thanks. If you know for sure that it's in thge right spot that will be ok also.
http://bitchincamaro.no-ip.com 91 RS Camaro 5-speed black w/t-tops 305 TPI
MODS: SLP cold air intake w/K&N, air foil,Accel 19 LB injectors, March aluminum under drive pullies, Alburn pro posi, Aluminum drive shaft, Random Technology 3'' cat-back, 8.5mm MSD wires, 160 thermo, jet fan swich, Custom chip with 91 vette computer, SSBC slotted rotors, optima battery in the rear, BMR adjustable lower control arms and panhard rod, Kenny Brown strut tower brace, TB bypass, no egr, no air
I replaced my Tuned Port Injection emblem with a 5.7 Tuned Port Injection emblem when I did my motor swap.
It goes on the indentation that goes all the wasy across the rear bumper cover, about 1 inch in from where the indention starts.
Thats where the originally one was.
1989 IROC-Z 355 M5
13.0@104
MACC All Camaro Show-
1st Place
3rd Gen Modified
1988 Chevrolet K-5 Blazer
6000 lbs. of a real SUV
2001 Yamaha Raptor
92 mph on radar!
[This message has been edited by Irocvette355 (edited September 05, 2002).]
1989 IROC-Z 355 M5
13.0@104
1st Place
3rd Gen Modified
2001 Yamaha Raptor
92 mph on radar!
here's a pic of a 100% stock 3,000 mile 86 IROC:
http://www.thirdgen.org/techbb2/atta...&postid=651816
The pic is hard to see, but I believe that IROCVETTE is correct in saying it's around 1" from the left within the recess.
The IROC Homepage
View the Restoration of an 85 IROC
Weekend projects aren't.
The IROC Homepage
Thats were it was when I put it on the first time. The bodyshop replaced it when they painted the bummper and put it all the way to the left. Just wanted to make sure I was right before I went to war.
Don't feel bad. I put mine all the way to the left too... and I used plastic emblem adhesive so there's no way for me to get it off without seriously marking up the paint.
The IROC Homepage
The IROC Homepage
07-04-2005 05:00 PM
