What cam for a 89 RS camaro 5.0 TBI
Re: What cam for a 89 RS camaro 5.0 TBI
Actually, putting an LT1 (or even an LT4) cam is a pretty common cam swap for 305 TBIs, and it works great. All you really have to do is grind down the dowel pin and install it just like any other cam swap. Although, like any modifying any other FI setup, the computer will need to be tuned to run at it's best.
It's not a very aggressive cam. Duration around 200-205* @050, lift in the low .400 range, nice wide LSA to preserve a smooth idle and keep the ECM happy.
Compared to the original TBI cam it's a fire-breather, but in the grand scheme of things it's still really mild. That's why it works well in the 305 TBI motors as a mild performance cam.
Originally Posted by 85_305
^How do you not loose power for going from a cam designed on a larger engine?
- Justin
I gotcha
Good to see you posting again though Justin; you planning on sticking around or what?
I'm still around don't worry, and you can always leave me messages on AIM.
- Justin
the lt1 cam is nice however the lt4 is better due to the 115* lobe sep makes more power than the 116-118 cams and tuning on this cam is minor(tbichips etc.)this cam also gets the benefit of 1.6 rockers as well.....
Originally Posted by Tru2Chevy
Now that the weather is nice again, I'm on a final big push to get my car out of the driveway, so less time spent on the boards. I've also been busy with the planning stages for the East Coast Nat's, the event my club (NJFBOA) is putting on this August at Island Dragway.
- Justin
- Justin
But I have sent you another PM, btw
NewsBot
12-24-2014 11:05 PM
