what oil do YOU use?
i recently chnged oil in my car, but i was feelin a little cazy, so instead of buying the same old valvoline, i got quaker state. i know i broke my family tradition, but i alway wanted to try it.
so i was wonder what kind you guys buy? and i dont want to hear from you redline oil, or royal purple guys. i want to hear from people that dont want to pay over a couple bucks a quart of oil like me.
thanks
thanks
Mobil One flows in my vehicles.......Quaker has better stats than most conventional oils, but if you do not change it on time..........BUILD UP CITY!!!!!!
You need to try Synthetic oils once.......When you do, you will not look back at the DINO JUICE!!!!!!
Later
Later
I use Mobil 1 15W-50 in my built motor, why, its great, its synthetic which has better wear prevention and break down characteristics, also, if the manufacturers ship their flagship cars with Mobil one, thats good enough for me.
I know the Vette and Vipers, Porches and others ship with it in their crankcases. If the builders use it, I do too, and I use an AC Delco filter
Synthetic oil doesn't "break down" like conventional crude type oils, and usually doesn't contain the "paraphen wax" that causes build up in the lifter valley etc..
I usually use Pennzoil, a wax free oil, in either synthetic or conventional is better...I prefer full synthetic.
I use quaker state peak performance, for the dino oil nothings better, I pulled my 305 apart for a rebuild and there was almost no build up. Now that I rebuilt the 305 I`m gonna switch to mobil 1
I change my oil every 3000km or every 2 months
If you go to syth. then you have to watch for leaks. Syths are thiner oil & can leak really bad. If you are running a stock engine & no rebuild or reseal stay away until you do.
My car is going to go syths after I reseal her up hopefully this winter but right now we use Havoline 3 10w30
