what was the tranny called in the 92 camaro's?
Old 10-26-2004, 03:38 PM
  #16
Marc 85Z28's Avatar
Re: what was the tranny called in the 92 camaro's?
Originally Posted by Tru2Chevy
Yea, in a lot of ways the '93 F-bodies were like a 3rd gen with updated skin.
- Justin
With the exception of a completely different front suspension, the new Gen II smallblock with a completely new intake design, completely redesigned interior and exterior, and some other misc items. Other than that, they're alike
Marc 85Z28 is offline
Old 10-26-2004, 10:49 PM
  #17
Scrote's Avatar
Originally Posted by Marc 85Z28
Beginning in 1991 GM changed all of its automatic transmission designations. The TH700-R4 became the 4L60. The newer names were essentially a code for determining the transmission. The 4 meant 4 forward gears. The L meant it was a longitudinally mounted trans, aka rear wheel/4 wheel drive. The last two 2 numbers designated the duty rating, or strength of the trans. The higher the number the stronger the trans.
So GM called the 700 a TH700-R4 until 1990. GM then called them 4L60s. So technically the 91-93 units never were called TH700-R4, even though the are the same transmission.
On a side note, nearly all auto manufacturers have done the same thing. All in the early to mid 90s too.
FINALLY someone else that understands...man. I always get so much crap from people..."no jackass my third gen has a 700r4 not a 4L60...those are the ones that the fourth gens have...." I get that all the time.....
Scrote is offline
Old 10-27-2004, 01:01 PM
  #18
Tru2Chevy's Avatar
I didn't say in all ways....just in several ways.
- Justin
Tru2Chevy is offline
Old 10-27-2004, 01:14 PM
  #19
Z28SORR's Avatar
- Justin
Well yah! They're both Camaro's, they both are front engine rear wheel drive, they're both built by GM. I quess that's several ways.
Z28SORR is offline
Old 10-27-2004, 01:15 PM
  #20
Z28SORR's Avatar
Oh, and just to add to the confussion, they're not BW any more they're TREMEC. That's the 5 and 6 speeds.
Z28SORR is offline
Old 10-27-2004, 01:19 PM
  #21
Tru2Chevy's Avatar
Identical rear suspension setup, same driveshaft, same auto tranny, same chip-based computer.....
- Justin
Old 10-27-2004, 02:04 PM
  #22
Z28SORR's Avatar
- Justin
Well there you go! Some more; both have two doors, a hatch back, beat Fords, gas tank in the same location, fuel door's on the left.
How far we going to carry this?
Z28SORR is offline
ChrisFrez
12-21-2014 09:47 PM
ChrisFrez
12-15-2014 03:09 PM
nballisru
12-14-2014 05:01 PM
ChrisFrez
12-07-2014 06:01 PM
ChrisFrez
11-30-2014 08:41 AM
Quick Reply: what was the tranny called in the 92 camaro's?
