What type of injection?
I am not the most knowledgable when it comes to motors. I know a few basics but thats it. Anyway, I am going to be starting on a motor for my 1990 RS and I was wondering what type of fuel injection to go with. I know of the different types: tpi, superram, ramjet, stealth ram. Just wanted to know what you guys thought.
Thanks in advance
1990 camaro rs
never raced it because, well its slow.
Thanks in advance
1990 camaro rs
Depends on the money you want to spend and the car's intended use.
Mike
'90 IROC-Z, 5-speed, ZZ4, G1 Trick Flows Moderator SEThirdgen
Mike
Multiport Fuel Injection on a single plane 4 barrel Carb Intake. Accel Part # 74139 , Plenum Adapter Accel Part # 74882 and your TB perferably a 52 or a 58. This combination dosen't hurt your RPM range. Rpm Ranges; TPI=4700-5000 MiniRam=5000-6000 Superram=5000-6200 This setup is good from Idle to 7500 If your cam can go that high. In my opinion nothing flows like a single plane 4 barrel intake..
Just my opinion you do what you want thou..
Kevin
86 Chevrolet Camaro Iroc Z-28 Fully Loaded With T-Tops
Mods;
Spohn SubFrame Connectors, S&W Race Car Chassis 8 point Roll Cage, 1997 SS Aniversary 3.42 POSI Rear End with 12" Rotors and 4 Piston PBR Calipers, Balanced Drive shaft... Others soon to come...
Best times before any mods done, Complety Stock;15.6 @ 87mph
Waiting for the tracks to open again to see what I got going on Now!
ntimad8.cz28.com
Kevin
Mods;
ntimad8.cz28.com
www.lt1intake.com
This guy converts LT1 intakes to fit your application. Very cool, and cheaper than a miniram. If I were ever to go the FI route this is what I would do.
1991 Camaro RS
www.sethirden.org
1991 Camaro RS
www.sethirden.org
CARiD
09-30-2015 05:44 AM
surreybrad
09-29-2015 09:00 PM
autoxr166
09-25-2015 04:21 PM
