Whats The Best Oil Weight To Use???
Hi on a new crated motor, what is the best weight of oil to use? I keep getting different results from everyone. I need a clear answer cause I dont want to harm the motor at all!! I live in west Tx so if you all have answers I would really apreciate it....Thx!!
Re: Whats The Best Oil Weight To Use???
depend where you live GM recommends 5W30 but 10W30 is good. never use a straight weight.
the ratings are read like this:
exmple: 5W30: this oil flows like a 5 weight oil at 0 degrees F and like a 30 weight oil at 210 degrees F.
when getting oil check the back of the bottle for the API donut. and make sure you get the proper rating. ex:SJ type. i forget what year range that oil is good for. you can check the owners manual or google it.
If it was my engine, then once I'd gotten past the break-in period I would use 0w-30 Amsoil. (Or any other fully synthetic oil.)
You might also consider getting a remote filter setup, especially one of those bypass setups that have a regular filter AND a bypass filter. Amsoil sells those too.
Oh and, for the record; I'm not pimping Amsoil because I sell it. I don't.
I use it and I like it a lot, so I tend to tell people about it.
Originally Posted by masiroc566
well the guys at pepboys told me to use 5w-20...which I am currently...is that good?
oh and from my experience people at auto parts stores generally dont know what they are talking about.
i once asked someone at one what a VSS was(before i knew) and i was told it was a vacuum starter solonoid. when it is a vehical speed sensor. and another time i asked where a radiator flush kit was and they handed me a a/c flush kit.
its not bad its just a thicker oil.
Originally Posted by robvas
No. Break your engine in with some plain jane 10W30. Don't run anything like synthetic until you get a couple thousand miles on it.
and no the thicker oil has nothing to do with it not reading.
Since you live in Texas where the climate is not to extreme just go with a good brand of 10W30. Also I suggest getting a 2qt A/C Delco oil filter (p/n PF-932)for that extra capacity for a total of Six quarts.
you can use a really crappy store brand oil for break in since its really heavy and will stick to parts during the critical break in, also use crappy store brand filter or fram filter since they flow bad but have good filtration. after 500 miles or so stick in 10w30 of a good brand like mobil one syn or non-syn depending on which way you want to go. and use a good filter too.
no you are wrong. lower numbers are thicker. higher are thinner.
Oil has 5 duties inside an engine:
1 to cool
2 to clean
3 to seal
4 corrosion prevention
5 to lubricate
I would recommend 5W30 as does GM but 10W30 is OK. At the 500 mile mark I would do a first oil change to Amsoil 5W30 or 10W30. 0W30 is a good oil but I live in Georgia and I prefer the heavier oils.
