what's going on
what's going on
my winter car just took a crap. i was driving it down I-65 and it wouldn't go any faster than 55. if i gave it more gas it just bogged down. next i looked in the rear view and saw white smoke, then it died. came back a few days later, started and it idled REALLY rough. finally after about 1 minute, it died and the dip stick shot up about 3 inches. tried again and got the same thing....but no white smoke. any ideas?
at first i thought head gasket, but now i'm not so sure.
any help would be greatly appreciated.
On my 89 Merkur, when the crankcase was pressurized by an bad PCV it caused the dipstick to shoot up and spray oil all over. However the XR4Ti is a turbo car and yours is not therefore I would suspect that a head gasket or something is leaking. What does the oil look like? Take a compression test.
Originally posted by nightrider
it's an 85 chevy celebrity. would a head gasket cause the dip-stick to shoot out???
what`s happened to your car is this one of your pistons has developed a hole in it or the ring lands have broken off the piston this will put oil in the combustion chamber and create white smoke
little oil burning =blue
lotsa oil burning=white
dipstick popping out=compression in the crancase(hole in piston)
85 Celebrity? 2.5L "Iron Duke" 4 cylinder by any chance? They are known for cracking the cylinder head... Just a thought. White smoke is coolant in the chambers 99% of the time, and a cracked head and/or a head gasket is the most likely cause.
thanks for all the posts. i think i'm going to have it towed to my house and tear into it on one of my breaks...but i will definately get a compression tester and let you know what i find.
