What's the most cost-effective way to increase LG4 horsepower?
#18
Re: What's the most cost-effective way to increase LG4 horsepower?
I used a Summit cam, Edelbrock intake, carb tweeks as well as DR rods and G hanger, and an L69 dual snorkel with KN, full L69 exhaust--manifolds, y-pipe, and intermediate pipe along with a high-flow cat (the L69 exhaust is essentially a 350 exhaust), and messed with the timing a bit. Awoke the old boy. No comparison, however, with the 350 HO Deluxe I'm currently running.
JamesC
JamesC
#19
On my 86 LG4 Trans Am, the best bang for the buck had to be the Edlebrock 1406 carb and 7101 Dual Plane hi-rise intake (and vacuum advance distributor).
$400 total at the time and got my car to run a 14.943 @ 92mph with a 2.1 60'. not bad for 165hp stock motor with 113K miles on it and only those mods.
I then did a TPI swap with TPI heads, Crane Cams Powermax 2050 camshaft, headers, MSD 6A, Blaster 3 coild, full exhaust, SLP Dual cold Air, 52mm TB, and the car ran a 14.1 @ 100mph with a 2.3 60' in Limp Home Mode. this was about $1500 total.
for comparison, the car in my sig only runs a 15.2 @ 91.5mph.
#20
I'd jump right on doing a intake swap (to at least a Performer, better yet a Performer RPM w/ a drop base aircleaner to fit under the hood, try to score one cheap on ebay or something) and a cam swap at the same time. Something cheap like the "Summit TPI Cam" kit that specs out around 204/214 duration @.050, .420/.442 for lift and runs a little over $100. Comes w/ springs and junk and runs pretty mild in a 305, together that will add in some serious horsepower even w/ the stock exhaust. Then I'd jump on exhaust next as money allows. Might as well buy the whole exhaust together, buy it for a single cat TPI car and you'll get 3 inch stuff. You can make 250+ hp easily w/ a LG4 setup like that.
08-24-2015 06:41 AM
C4m4roJoe
07-19-2015 10:59 PM
