Wheel locks
Wheel locks
Can some one tell me if wheel locks were an option in '88 or do I need to look at aftermarket companies to find the key. The car didn't come with them and I can't get the wheels off. Is there any other way I can get them off?
http://web.camaross.com/bb/Forum26/HTML/014275.html
If it's a GM lock, a dealer ought to be able to remove it easy. Mine were aftermarket but they still got em off.
You can buy a tool which looks like a lug socket except it's tapered inside and has teeth. Bash it onto the lock with a hammer than use a socket wrench. Easy.
[This message has been edited by Z28Marcus (edited September 04, 2002).]
try tightening the the lugs on either side of the lock then with a vise grip clamp it on while turning hit the lug with a hammer if they are loose enough they will come off like this.
If not you may need a shop to use a reverse thread socket and an air gun to get these off, don't let them use a torch or cut them off.
I removed hundreds of locks these two ways or with an air hammer and a flat chisel bit.
carguyshu
01-22-2017 11:19 AM
