Where would I run the wires from battery in the trunk?
I'm moving my battery to the trunk, and I was wondering where the best place to run the wires is. Anyone here done it, and where did you run the wires?
good question, i'm getting ready to do the same. I don't know if inside the console (underneath it) would be ok. Maybe somebody on the list has done this. If so, please answer it for both of us. ttt
Brian
Brian
in my 79 i ran the (+) batt cable along the frame rail up to the front . i ran the ground cable to a rear sway bar mount (sway bar was removed) just needed to drill 2 holes in the trunk , and the kit from summit came with rubber grommets to keep the wires from rubbing on the bare metal
squarehead
11-21-2014 08:02 PM
Wilson
07-21-2002 05:08 PM
