Who wants a K-Member?????
This thing is a go!!! I placed my order today, only need six more to get this all and all out going.. Once we have seven there is no limit to how many we can get so come one and come all to the K-member sale!!! You lose 32 pounds off your front end, and you can pick between red or black , with or with out motor mounts and spring perches..
AGAIN $409.00 FOR MILD STEEL WITH MOTOR MOUNTS AND SPRING PERCHES (PROBABLY LESS FOR K-MEMBER WITHOUT THEM)
$509.00 FOR CHROME MOLY WITH MOTOR MOUNTS AND SPRING PERCHES (PROBABLY LESS FOR K-MEMBER WITHOUT THEM)
CALL PAUL TODAY @ THUNDERRACING
@ 1-887-516-7223
YOU SAVE $70.00 RATHER THAN PAYING FULL PRICE FROM THE MANUFACTURER, AGAIN THIS IS A PERFORMANCE AUTOMOTIVE K-MEMBERS!!!!!!! CHECK OUT THE WEB SITE @ WWW.PARACING.NET
THANKS
__________________
@ 1-887-516-7223
THANKS
__________________
Yeah, it bolts right in.. Works great looks better, and know one will know unless the crawl or you tell them, or they notice how when you stomp your foot to the metal your front end wants to crawl to the sky..
If seriously interested please give Paul a call
Kevin
Kevin
Anybody can use them, if you do autoX I would recommend the chrome moly verison.. They lighten your car and make the front stiffer, and gives you better ground clearance, and more room for headers
Re: ghmgfmkj
FYI for those who dont know. the benefit of the kmembers is 1)lightweight 2) improves header clearances and makes eng. more accessable 3) looks sweet 4) is structuraly (Sp?) stronger.
Ive hear that they save 72 lbs. but that may be with chromoly and w/the tubular A-arms. I wish I had the money to do that now. but I need alot of other stuff first. like some subframe conn.s.
chris
chris
what is the difference in the chrome moly and mild steel...
100.00 bones and how much weight are you looking at...
strength difference... I hate to get mild steel and have it break...
just to have some DUDE go "bro you should have gotten Chrome moly"
oh yeah if I want to upgrade to the steering kit that they sell?
is it compatible with this k-member?
rack and pinion style...no power steering pump....thing! I can dump that HUGE gear box then...
I had to get the frme welded from racing....Stupid gear box!!
Do you have any long-term experience with this particular model yet? I've heard from others that some of the k-members that are currently available can't hold up to daily street use, and should only be used on a drag-only car. There's another more expensive one floating around that's supposed to be strong enough to handle daily use. Has this one been tested on a daily driver? The price sounds right, but the last thing I need is to crack the thing in 2 years on the way to work.
I've spoken with a couple of guys on here that have them and they say they work great the mild steel versions.. I spoke with Performance Automotive and they say that the chrome moly version is recommended for autocross racing but the mild steel version has yet to have any problems and it's been out on the market for close to three years..
