whole mess of 3rd gen questions
#16
Location: Teeter-tottering between Brilliance and Insanity
Originally posted by Jim85IROC
That depends on your idea of "nice" and also has a lot to do with your geographic location.
3-4 grand around here gets you a whipped 120k 87 305 with a sh*tty interior and paint that isn't much better. 4-5k starts to get you into nicer stuff that only needs minor things.
1. Straight body, no rust at all.
2. Engine that runs strong, and throws no codes. Doesnt leak any fluids
3. Tranny, and rear end seem to be in good condition
4. Paint, it can be a little faded, cause its an old car, but it has to BE ALL THERE. No chips, or missing paint.
5. Interior, the same it can be obvisoly not new, but no extensive tearing or cracks in the dash.
6. SOund system doesnt have to be top of the line but it needs to work
7. T-tops are gonna leak, but I would rather not get monsooned everytime it rains since I live in Florida.
8. Any power acessories the car has needs to function, and while not a must, I would pay an extra $300 for cold AC in a heartbeat. Its damn hot down here 10 months out of the year.
I think if one is patient you can get that for upper 3k or lower 4 pretty easily. At least down here you can anyway.
#17
Originally posted by locosteelersfan
In case your looking for it, you should know
that there were NO manual transmission with
the 350(L98). You could get a 5sp 305 Z28.
Also know that there is a big difference in the
305's. The RS is a TBI and isn't very strong,
while the TPI has a lot of TQ and with the manual
is a fun car.
The TPI's look nearly identical so check the VIN.
People frequently claim 350 when they don't have it.
The 8th digit is F for 305TPI and 8 for 350
Hope this helps
is a fun car.
Hope this helps
The 305 TBI is not just the higher end RS motor, it is actually the base IROC motor as well
#19
Are you sure about that. I think all IROC's have TPI's..
Is yours not a LB9?
Is yours not a LB9?
#20
Is yours not a LB9?
Is yours not a LB9?
91-92, it only came in the base firebird and the RS
#21
see some tech data here http://www.thirdgen.org/newdesign/tech/techdb.shtml
#25
I know your mainly intersted in the L98 but I wouldnt count the LB9 out if you came across a good deal. I got mine(car in the sig) w/ 88k for $3500. w/ minor mods I had mine into the 14's.
Bone Stock - 15.6
Flowmasters 40 series muffler - 15.3
tune up Accel cap, rotor, 8.8mm wires, NGK plugs, Nitto's NT555R, removal of some belts - 14.9
Homemade ram air and bumped the timing from 6 to 10- I'll let you know this weekend.
As you can see, if you get one that is unmolested, and w/ low mileage, they can easily beat some L98's.
Bone Stock - 15.6
#26
Rage, a 7/10's increase equals about
70rwhp. Think you may just be getting
more use to the car I mean I wish I could
buy a muffler and plugs to get that.
I'm not being a smarta$$ but those mods
wouldn't get you anything near that type
of gain.
of gain.
#27
of gain.
of gain.
#28
You also seem to be "stacking" the mods.
Meaning you can't just add up all the advertised
gains and say I now have this or I now can run
this.. I doesn't work that way and No ram air
is going to give you 20 hp or 2 tenths. The ram air systems
really don't do much under 100mph and you
aren't even trapping that.
#29
You are right about the ram air but if he is using the design that I think he is then it would work very good for CAI, considering
1. the engine is getting air from outside the car, not the air in the engine bay.
2. the air boxes on 3rd gens are very restrictive and by cutting the bottoms of them off relieves a good deal of this restriction.
#30
You also said ram air doesnt do much under 100mph which is horribly wrong. You cant ram air at automobile speeds it doesnt happen. What you end up with is a very good cai system that will help you all through your power band.
