Why is my car ideling hot?
Yeah, my car runs really cool but when it idles for a little while after I have been driving it for about 5 min, it starts getting really hot. Should I replace the thermastat? Also, what temp should my fans kick on, I took it up to 230 and the fans never came on so i shut them down, but I do have an SLP fanswitch that Im about to connect if that will help, unless someone knows the problem.
Blue 87 IROC-Z Camaro,305 TPI
3" Flowmaster
3" Flowmaster
Sounds like a fan switch to me....Check your fan relays and the fusible links. Also, turn on A/C and one of your fans should come on. If nothing solves your problem...then do what I did and hook up a Manual switch to your fan (I just got one hooked up 60 amp load kept blowing inline fuse).
Later
1989 Formula 350
K&N air filter, air foil, TB Bypass, AFPR (set at 45 psi), A.I.R. yanked out, Accel 8mm wires, Fireball external coil, Pulley (just the crank), gutted MAF, corvette servo, Hooker super comp. shorties, 3" exhaust all the way back, No cats, Flowmaster 40 series muffler (one in one out turned down)---Developed a bad habit....bottle related!!!!75 Shot of Nitrous
http://www.theformulasource.com/owne...php?siteid=144
So they made him get rid of it...For decency ya know....But it came back the next day...
My webpage:www.cardomain.com/id/1fastformula
Later
1989 Formula 350
There is also a plastic part that pushes air up into the radiator and keep the hot air from the engine from getting into the radiator. If you are missing that it will cause the engine to run hot.
http://bitchincamaro.no-ip.com 91 RS Camaro 5-speed black w/t-tops 305 TBI now TPI
MODS: SLP cold air intake w/K&N, air foil,Accel 19 LB injectors, March aluminum under drive pullies, Alburn pro posi, Aluminum drive shaft, Random Technology 3'' cat-back, 8.5mm MSD wires, 160 thermo, jet fan swich, Custom chip with 91 vette computer, SSBC slotted rotors, optima battery in the rear, BMR adjustable lower control arms and panhard rod, Kenny Brown strut tower brace, TB bypass, no egr, no air
Most likely a fan problem. My stock fans(both, yes both) are wired to a switch in the car. Entirely using the stock fan relays too! Don't ask me how but a friend of mine did the work. It'll idle at 160 all day in 100 degree traffic. 180 thermostat too!
Denny Villemure
1989 Camaro IROC-Z Convertible, 305 TPI, 2.73 Gear, Flowmaster 2 chamber. 15.60 on motor, 14.20 on a 75 shot from NX. Woo hoo!
www.denny.cz28.com
Denny Villemure
www.denny.cz28.com
I had a similar problem. It turned out to be the coolent temp sensor which is just under the maf on my 85. It is hard to see and get at. Jump the fan and if it works the CTS might be the problem. This is not the temp indicator sensor which is on the head. This sensor gives info to the computer which controls the fan.
Bob
Bob
Thank you all, I put all of that together and fixed my car. When I bought the car, the battery cable would barely reach the battery, I had to stretch it, well, while in the process of stretching it, my fans became disconnected, so I found that, also, I checked my thermostat, turns out it wasnt turning over, it was stuck, so that was another prob. Now it runs good. Thanx guys. I put a 195 thermo on there, is that ok?
3" Flowmaster
3" Flowmaster
<font face="Verdana, Arial" size="2">Originally posted by Rage:
</font>
</font>
Not sure about that but I have absolutely no difference between a 160 and 180 stat. In the summer (95 deg day) , with the AC on in traffic, the car gets to around 180 - 220 anyway. In any case, the engine goes into closed loop around 125 so it would manage that AFAIK.
