Wieand 144 or 142 Superchargers
#16
Re: Wieand 144 or 142 Superchargers
Originally Posted by S. Holley
TO much porting...(as in porting the hell out of them can effect your low end punch) This is not a race motor but street. if you use a higher rpm cam and plan to turn the motor high and hard... cool, but your factory camshaft works from .100 to .400 lift...maybe 4500-5000 rpm.
Just my .02
port sure...hog it out....not for stock motor stock cam engine.
Just my .02
#17
yea i would change the cam also if you guys maybe thought that was a problem......but i truely don't know how this is gonna work if i can't fit under my ss hood...cuz there is no way i'm gonna get a new hood...is there an alternative??? maybe a cheap centrifugal charger that somebody knows about???
#18
Have you considered adding a fiberglass cowl to your existing hood?
http://store.summitracing.com/eprodu...+400038+308354
BTW, supercharger and cheap don't work in the same sentence.
#19
no i can't be adding anothe cowl on top of my ss scoop...that would pretty much just wreck the looks of the hood...i think i'm gonna look into something else, maybe like a 450 HP crate motor or something..thanks for all the input tho guys...
#20
what about running a Paxton or equivalent S/C?
that would sit on the side of the motor,but instead of being on a fuel injected car,you could buy a "bonet" to go onto the carb to replace the intake tube that would be for fuel injection.
sorry if that doesnt make sense,hopefully you can get the idea.
that would fit under a stock hood
