Wiper fluid wont come out!
Hey guys when i pull the lever for the fluid 2 come out it wont work! can anybody help me out on this i dunno what it could be. probably sumthin simple but im learnin about cars thru my iroc so im gettin there. thanx all
Don't start the car but put it in run position and try the wiper fluid spray. If you don't hear a sound go to the wiper motor and hook up a light there where you can see it and try flipping the switch. If it lights up there is power at the pump. In that case, buy a new pump. If not you need to trace wires and what not.
I went through the same thing. I even went through the trouble of swapping the motor, still did it. It works now, but unless you use it daily, even as I do, it still sticks. I always heard the motor, just nothing came out. I find that if I give the car gas, or stop quickly, the sudden change in motion sometimes forces the liquid through. Weird, but it never fails. I changed all the rubber hoses, lubed everything up, still does it. Sometimes I can sit there and hold that thing for a good 25-30 seconds before anything comes out. Its a pain, but not much you can do. Hope that helps//
Will
Will
WobblySausage
10-07-2015 10:09 AM
autoxr166
09-25-2015 04:21 PM
