Would I run 12's with this??
#17
Ought to be a real good setup. My 87 is similar and it should be running 12's but it needs more cam and tuning and a higher stall converter. I love the way the miniram pulls upper rpms with my proted TFS 23* heads. I have a Hotcam in now but i'm going to the comp XE 224/230. Anyway, like i said, it ought to be a mean setup. Ed wright is good! Both my car's are speed density setups and I get Alvin at PCMforless.com to do my tuning.
Jake
Jake
#20
I was just pointing out that Ed Wright and Fastchips (Ed owns Fastchips) are 1 and the same. Since the two were mentioned seperately I assumed that there may have been some confusion. Mail order tunes lack the dead on tune that one can achieve by dialing in a setup with a self tune, no question.
#21
Originally posted by kandied91z
i was under the impression that maybe you were looking to buy so i thought i'd put my .02 in. nothing more.
seeing as you have the parts already i would use them too, might as well try it. as far as et i'd mid 13's if you use the tpis chip....if you get low 13's i'd consider it lucky and anything into the 12's would be a blessing. a little work done to the heads and intake will make a big difference in that area too though, hope it works out for you well.
10-31-2016 11:09 AM
