BBC in a 4th Gen Project
Old 07-04-2008, 10:01 AM
  #16
bmwmcars's Avatar
what headers did you use? and do you have to drop the motor to do plugs?
looks good!
bmwmcars is offline
Old 07-04-2008, 10:25 AM
  #17
ulakovic22's Avatar
Originally Posted by Joes96z
my headers from Lemons. They are being built as we speak. Motor specs on the way, i know its going to be a 496 Big Block around 640 Horse.
I will update when I can
Thanks,
Joe
ulakovic22 is offline
Old 07-04-2008, 05:48 PM
  #18
mdacton's Avatar
how much were the headers and how are they working out?
mdacton is offline
Old 07-04-2008, 07:41 PM
  #19
bmwmcars's Avatar
Originally Posted by ulakovic22
doh, i need to read instead of looking at sexy bbc pics
bmwmcars is offline
Old 07-04-2008, 08:32 PM
  #20
Joes96z's Avatar
Headers were $1300 uncoated. Then $300 to coat, but they fit perfect.
Joes96z is offline
Old 07-04-2008, 08:51 PM
  #21
mdacton's Avatar
is access to everything good?
plugs and starter?
Thats not a bad price at all.
mdacton is offline
Old 07-05-2008, 07:55 AM
  #22
slowride94z's Avatar
that would kill me, I'm still going the hooker route
500 maybe but 1300 no way
mdacton
I see your thinking more about the bbc since your recent round of bad luck
good luck Joes96z
slowride94z is offline
Old 07-05-2008, 08:00 AM
  #23
mdacton's Avatar
mdacton
good luck Joes96z
I been thinking about it for years
$1300 is cheap compared to having a set made.......with a project like that I would spend the money on good headers.
mdacton is offline
Old 07-09-2008, 08:17 PM
  #24
ulakovic22
thread jacking in progress, what does the header clearance to fire wall look like on the pass side?
Old 07-24-2008, 12:34 AM
  #25
reamo04's Avatar
wondering how plug access is? Picked up a 454, so yeah
reamo04 is offline
Old 07-24-2008, 10:16 AM
  #26
ulakovic22's Avatar
ulakovic22
Sorry I haven't checked this thread in a long time.
I have two experiences with the HKR-2455's with the BMR k-member. With a Mark IV 454 using 990 cast iron heads the headers fit and the problem was #8 I believe. It's a rather large problem and requires re-routing that primary. I cut the section out that was hitting the firewall to see what had to be done and you have to beat the hell out of your firewall or loop it and route it straight down.
Using a Gen V block and RHS heads the headers won't even fit. The configuration of the heads moves the exhaust port and they are meatier so the primary tubes actually hit the k-member at the back mounting point of the LCA and won't bolt flush. I'm trying to decide what to do. I can either relief cut in several spots on the primary and bend it or use a torch and heat the tubes and try to move them around. Either way is a real PITA. Would I rather spend $1300 on a set....hell no I would like to have an assortment of headers because I'm sure there is a set that can be used, it's just access to them for trial and error fitment.
Last edited by ulakovic22; 07-24-2008 at 08:06 PM. Reason: Forgot which side of the motor I was on :)
Old 07-24-2008, 07:38 PM
  #27
I got my 2455s two weeks ago, got them on and had to cut the fire wall where the hvac went. no problem because I hadn't sealed it off yet. that is the # 8 tube that hits. on my heads the headers had to be ground on the flanges where the bottom head studs hit, the studs are just tall enough to interfere. this is the third set Ive done like this.
Old 07-24-2008, 08:26 PM
  #28
reamo04's Avatar
also, are you using a standard height block, or what?
I have a 454 that i am building for my swap now, but its going to be a little different hehe
reamo04 is offline
Old 07-24-2008, 08:49 PM
  #29
klrz28's Avatar
That is one sweet lookin setup. Thats my dream.
klrz28 is offline
Old 07-24-2008, 08:54 PM
  #30
ulakovic22's Avatar
Who are you asking?
Quick Reply: BBC in a 4th Gen Project
