BBC in a 4th Gen Project
Old 07-24-2008, 08:57 PM
  #31
slowride94z's Avatar
sorry I had company this late.
mine is a 72 corvette block with 67 corvette aluminum heads, 4 bolt, studs top and bottom an L88 copy
haven't looked at the plugs yet , should be the same as any other bbc the headers aren't in the way here. when this engine was in my 68 camaro I was surprised how much easier it was to do the plugs compared to a small block, every thing is spaced out better
Ive cut the cowling back to the windshield the width of the engine. looking at different intakes , weiand team g dominator, edelbrock c454 dominator , and china team g? with 4150 flange. trying to keep the carb low, and don't have a dominator
fi is not an option for me
ulakovic22, how is your steering arm clearance? and how low is your headers?
slowride94z is offline
Old 07-25-2008, 08:33 AM
  #32
ulakovic22's Avatar
Steering shaft clears just fine because the headers loop back behind it. Another set of headers might call for the shaft to go in between 1 and 3 primaries though. Headers aren't any lower than LT1 headers.
ulakovic22 is offline
Old 08-06-2008, 07:09 PM
  #33
up date joe ???
Old 08-23-2008, 05:13 PM
  #34
Joes96z's Avatar
Joes96z is offline
Old 08-23-2008, 06:17 PM
  #35
OH MAN THAT IS CLEAN
mines gonna look like stinky, no where near that nice
damn-good job, have you driven it yet?
Old 08-23-2008, 06:34 PM
  #36
Joes96z's Avatar
I have driven it for about 10 min to a local car show (won best engine). I still need a front end alignment and work out some of the bugs.
Joes96z is offline
Old 09-12-2008, 07:24 PM
  #37
what kind of hood is that Joe ?
does the front feel heavy?
Old 09-13-2008, 11:36 AM
  #38
Joes96z's Avatar
It is the Big Block Hood or stinger. The front does feel a little heavy.
Joes96z is offline
Old 09-24-2008, 12:29 PM
  #39
Joes96z's Avatar
Well have my first problem. Car is overheating bad when I drive it for about 10-15 minutes, the temp gets to about 220-225.
Any ideas out there???
thanks
Joes96z is offline
Old 09-24-2008, 01:26 PM
  #40
slomarao's Avatar
water wetter??
I need to see this thing. Im local, what shows do you go to?
slomarao is offline
Old 09-24-2008, 05:20 PM
  #41
what kind of radiator? is it lean, or vacuum leak?
how thin are the cylinder walls? has it been run much?
I had a rhs 406 that boiled over 4 times before it really broke in
Old 11-22-2008, 11:33 PM
  #42
KENS96M6's Avatar
Any new info? Cooling problems solved? Great looking engine bay by the way! Thanks
KENS96M6 is offline
Old 05-12-2009, 02:48 PM
  #43
Joes96z's Avatar
sorry its bin a while, figured out the overheating the radiator was too small. So today I ordered a custom double pass one from griffin. I also am switching my QA1 springs to 325 because teh 275 are too soft. Any othe rinfo i will let you know.
Joes96z is offline
Old 05-13-2009, 02:38 PM
  #44
95Blackhawk's Avatar
Originally Posted by Joes96z
Figured out the overheating the radiator was too small. So today I ordered a custom double pass one from griffin.
Make sure and please post on the results of the radiator. I am fighting an overheating problem on my 383 and want to know if a new radiator is in the picture.
95Blackhawk is offline
kolbaso
05-21-2015 01:49 PM
ad356
04-16-2015 05:38 PM
ChrisFrez
03-22-2015 09:12 AM
Roadie
02-16-2015 10:34 AM
Quick Reply: BBC in a 4th Gen Project
