Connecting rod-to-block clearance issues...383...HELP ASAP!!!
Well, I bought the whole rotating assembly (383 stroked LT4) that I want to go with for my car and I have it down at the machine shop right now. The machinist was just getting ready to clearance my block and he called me and said that he was worried about grinding into a water jacket because of where the connecting rods are hitting the pan rail at.
The parts go as follows:
Eagle lightweight forged crankshaft - 1-piece seal
Eagle 6" h-beams w/ L-19 - CRS6000B3DL19
JE forged flat-tops 12:1
What should I do?? Should I tell him to go ahead and take the chance??? Has anyone ever run into this at all???
Any help is appreciated...
![Wink](https://www.camaroz28.com/forums/images/smilies/wink.gif)
Re: Connecting rod-to-block clearance issues...383...HELP ASAP!!!
The Eagle rods are not particularly good wrt stroker clearance. The heads of the involved rod bolts may need to be ground for adequate clearance. On my previous motor we hit water when clearancing (Lunati Pro-Mod rods, which have more clearance than the Eagle) but were able to use Devcon epoxy to seal it. The Oliver billet rods have excellent clearance, but cost $1,200!
Rich
Rich
Gotcha...is that going to lessen the strength of the bolts or should I worry about having the bottom end coming apart because of clearancing the bolt heads??? The bolts are the L-19 bolts BTW...
Thanks for the help!!!
![Bow](https://www.camaroz28.com/forums/images/smilies/bow.gif)
Thanks for the help!!!![Bow](https://www.camaroz28.com/forums/images/smilies/bow.gif)
Rich
I used the Eagle cast steel crank and the Eagle S/R 5.7 rods, they almost didnt need clearncing. The machineshop that clearanced my block used a template mesurement they had and I have almost twice the required clearance, with no jacket intrusion. My pan rail didn't need notched either , just the bottom of each cylender.
One more option if you haven't bored the block is to put a small amount of block filler in it. That will seal it up just in case you grind thru anywhere....
Nayr
03-03-2023 08:34 PM
Henson071
09-21-2015 04:31 PM
