Cutting grooves into heads
#61
Sounds like a good enough reason right there, if it idles better (no loading up) and fuel consumption is better (more efficient burn). How much would this typically cost to have a set of heads modified this way?
#62
There does not appear to be a down side to it. The way I look at it is there is a gain or there is no benefit. Doesn't sound like it could hurt to try it.
I liken this to the aero wings I had cut on my crankshaft counterweights. I'm only expecting to turn no more than 6300rpm. Some people said it was a waste of time for my motor. Others said a small benefit would be gained. I did it anyways incase there was an easy 3-5hp to be had. If I had known of the grooves earlier I would have had it done. Could only help or not hurt anything.
#63
http://www.powrehaus.com/
Mike Holler
email: mpgmike (AT) powrehaus (dot) com
(717) 438-3767
3424 Liberty Valley Rd.
Ickesburg, PA 17037
#64
10-31-2016 11:09 AM
stockssn2o
05-25-2015 08:54 AM
