LT4 heads and rocker-girdles...
It would appear that the LT4 heads don't accept a regular SBC rocker-girdle. Both of the ones I have on hand are "off" on the exhaust stud be a good bit.
What are you LT4 headed guys running? Part #s?
Thanks.
Thanks.
Re: LT4 heads and rocker-girdles...
Originally Posted by Birdie2000
I have AFR LT1 heads and my Jomar girdle fits fine.
Z8's, is that crane girdle for centerbolt valve covers?
No I have my heads setup for perimeter valvecovers
You can get a Comp undrilled one and then set it up exactly for your heads. Not bad when you have a mill on hand to get it done. The AFR (except 215 RR) valve centerline is tradtional SBC where the LT1/LT4 is like the bowtie valve centerline, so yeah you might have problems with finding the right stud girdle for the heads. IF the Moroso one works on LT1's it should work on LT4's
Chris I thought your car had AFR's on it?
Bret
Bret
Bret
will this fit? If I drill out holes for the valve cover bolts?
http://cgi.ebay.com/ebaymotors/ws/eB...33624#Shipping
Matt
Matt
Matt
Matt
he needs the vortec type
That type will not work becuase the bolts that hold the two halves together are were you need to drill. The kind I have (Moroso) are the type that have U-bolts squeezing the poly-locks and they already have the hole cut in them. They were like $125 from Summit.
10-31-2016 11:09 AM
95chwagon
01-13-2015 09:19 PM
