stroker owners help?
i am having serious problems getting my new motor in the car to run right. it feels like the spark is breaking up really bad. i scanned it and the left bank is lean (small leak at y pipe before O2), and the right is rich. i yanked my plugs (TR6) this evening and they were all fouled. i put some dry autolite 104's in gapped at 0.040" and the car still seems to run funny. the motor is supposed to have a CR of 11:1 and i have a mallory hy-fire VI CD ignition. i gapped the plugs in the stock motor to 0.040" because i spray a 150 shot. should the gap on the higher compression motor be larger and would this cause my problem?
i posted it here so i don't get responses from a bunch of kids saying what they have their factory gap at on their cars. i am not trying to be rude, i have just seen it happen too many times.
Spark plug gap is least of your concerns. Fix your exhaust leak so that your cars PCM can attempt to get a handle on your A/F ratio. Exhaust leaks before an O2 sensor allow oxygen into the exhaust stream causing the PCM to think that bank is lean. Once you have the obivous problems fixed, get to a chassis dyno with a wideband O2 sensor and find out what is going on.
First I agree with Josh on getting the other problems fixed first. As far as plug gap i normally see .035-.040 for a nitrous motor.
And ky94transam, no we love traffic in here. But appropriate traffic and people with attitudes unlike yours.
I would move this for you to LT1 Tech, but you will have to repost your question there now, thanks to ky94transam.
Originally posted by ky94transam
Watch what you post moderators seem to not want any traffic in here.
Fu** you and your attitude! Mr. Injuneer
"Mr." Injuneer
ducttape1975
07-10-2015 06:29 PM
