a ? about stock wiring harness and higher wattage bulbs. I did a search too.
Old 02-11-2005 | 11:34 PM
Z95m6's Avatar
I got kind of a simple question. I did a search and found several places on here where it said the stock head light wiring harness is capable of handling 2 130 watt bulbs as long as you put in 30 amp relays. Ok thats cool, but does that mean you can run 2-130 watt bulbs in the low beams and 2-130 watt bulbs in the highs? I just bought a set of 2-100 watt bulbs to put in my Hella FF75's for the Lows and i was wanting to get a set for the Highs also. Would that work if i wire in the relays? I guess i'm wondering when it says on you can run 2-130 watt bulbs on the stock harness is that total or is that just for the highs, and the same amount for the lows. Thanks
Old 02-12-2005 | 12:38 AM
Lower's Avatar
Re: a ? about stock wiring harness and higher wattage bulbs. I did a search too.
If you are properly wiring the relays it won't matter how many bulbs are on or how large they are -as the power will be coming directly from the battery, NOT from the OE wiring. The OEM wiring would only be used to activate the "switch" inside the relay.
phatbasslines
01-13-2015 05:03 PM
siguy
11-27-2014 10:07 AM
Rich_z28
08-27-2002 12:20 AM
Evilfrog
08-07-2002 11:36 PM
CobraEatr
07-23-2002 06:32 PM
Quick Reply: a ? about stock wiring harness and higher wattage bulbs. I did a search too.
