B&M hammerhead shifter will this fit on my car?
Hello everyone i have a 1995 firebird formula 6spd with a pro 5.0 shifter with lous short stick. I've been checking out alot of different shift ***** and wanted to know if the B&M hammerhead t-handle would fit on my car? Thats one of the best shift handles i've seen and really want it. If it can't fit i guess i would get one from flameball.com
Thanks in advance
kyzer soze
Thanks in advance
kyzer soze
Originally posted by Red1
If the shifter hole is way too small you should be able to drill and tap it to fit
also thanks for the replies
also 96z i checked your webpage out but couldn't find it.
If you know the thread you need you can go to the hardware store and get a tap that will cut new threads into the handle.
On the tap package it will tell you the drill bit size you need for that tap. You just need to drill out the handle and run the tap through it. Make sure while tapping you go a 1/2 turn foreward, then 1/4 turn back over and over.
Here is a pic right here.
http://community.webshots.com/photo/...38762840vKVsfR
How did you do it? how's it look? And where the heck are the pictures
His right about the pic thats the other b&m handle the one i have is the hammerhead t-handle
Originally posted by Lions3
My point is, you don't have to spend any money on machining at all. B&M makes a Hammer Head specifically to fit T5 and T56 sized threads = No modifications necessary.
