c5 steering wheel on my 00 SS
#22
Re: c5 steering wheel on my 00 SS
Originally Posted by stik6shift00
i dont know how to change it, i know you have to dis arm the air bag...unless you want a BIG suprise
#24
C5 wheel won't just bolt up . The center hole in the wheel is smaller than the F-body . Youd have re-spline the hole in the vette steering wheel to work with the F-body upper steering shaft . $$$ Or you could replace the f-body upper steering shaft with a c5 upper shaft , that would swap over , but it is a pita tearing the steering column apart , then getting it all back together .
#25
If its stock is it a direct fit or did you have to modify?
#26
Originally Posted by firehawkformula
Nice job on the conversion of your 95, 2 questions, how did you get the 97+ guage cluster to work? and is that a stock pontiac radio you have or after market
jasonduaine
06-04-2015 09:29 AM
