cracked dashboard
cracked dashboard
sorry, I dont have pics, but since I live here in houston, its hot, and its humid. so; things crack and such.
I have a crash all across my dashboard, the very top peice, from the windsheild all the way up to the steering wheel, and is there some kind of glue I could use to seal this, or would that just get really messy..
I talked to someone about it, and they said ~$2000 to get it fixed, thats sounds outrageous, and way too much, but, I dont know.
has anyone ever had this problem, or know how much it would be to get it fixed, or how I could get one off a car at a junkyard?
[edited for sig]
[edited for sig]
Re: cracked dashboard
oh awesome! yea! thats the peice, sweet thats alot more into my price range heh.
will probably cost a little more from my local car shop, but after seeing how resonably priced they are, I think ill get it fixed.
Pretty simple... You have to remove the pillars on each side of the windshield.. If you have t-tops you need to remove the t-top and there's a couple of screws you take out and the trim pops off by pulling it... Without t-tops I believe it just pops off by pulling on it... The dash pad is held into place with 6 round velcro type fasteners... 5 at the rear of the pad and one right at the point in the front near the defrost vent... You basically pull the pad off the velcro fasteners and finagle it out of the car... Just be careful putting the new one in so you don't crack that one... They're big, thin, and awkward.
well alright, that doesnt seem to complicated..
are you going to have to apply alot of force to get it back in place, or will it snap in and slide on pretty easily?
the only thing im worried about is this little red light thingy in my defroster vent..
it blinks when my car is off, I'm not sure if its an alarm.. or something with the system the previous owner had installed.. it doesnt come out.
I replaced mine and I had to get it in just the right position for it to slide into place... Once it's in you can just press down slightly in the areas where the fasteners are... There's grooves on either side of the dash pad that the a-pillars slide into which hold the pad down also.
I'm sure the alarm light will slide out once you have the old pad off.. You'll have to snip the wires to it then you should be able to push it from the back and it will slide out.
okay, any little prongs that could possibly be broken that I should check for before I buy one of those?
im looking at
this blue one
right now, because thats the stock color mine is, and I'm just making sure I wont get it and find broken off hinges or anything.
im looking at
this blue one
Oh you have a 97+ car or a Firebird.. Might want to add the year, make, model of your car in a sig so we know what car you have... The setup with the velcro fasteners and locations were for a 93-96 Camaro... So they may not be in the same location on yours... The pad might be held in a totally different way also.. I'm not sure... Maybe someone with the same type can shed some light on that.
bleh carpet on my dash..
I think im just going to go grab one off ebay from a 98-02 camaro, and install it myself, if it doesnt fit, ill just re-sell it.
