face gauges?
Camaro World has a write up, but it's very easy. Remove the two screws at the top, remove the panel under the column, loosen the bolts on the column support bracket.
Rmove the cluster facia, remove the screws holding the cluster and pull it out.
Takes about 15 to 20 minutes to remove if you take your time.
RX Speed Works
09-11-2015 03:31 PM
jackpawt883
09-10-2015 08:53 PM
