firebird dash into ls1 camaro
My dash is pretty messed up due to the PO getting in an accident and the bags deploying. They replaced the bags but not the dash. The local junk has alot of firebirds, but only one 97+ camaro (which is cracked), and I do like the way the firebird's dash looks... was wondering if one would bolt up... looks like almost the same setup.
Re: firebird dash into ls1 camaro
The firebird dash will bolt up to any 97+ Camaro. The only pieces that are not interchangeable are the headlight switch and the fog light switch. Also the firebird dash doesn't have a spot for the ASR switch (if you have it). The connections for everything are the same except for the fog light switch, the wires are different colors but they're pretty easy to figure out(6 for each).
Just remember that if you do the swap, your headlight switch will light up red and everything else will be the Camaro's blue-green color. The overlays are different shapes so you cant directly swap them either.
Well I had been wanting to do custom gauge faces anyway, and everything else looks like it should fit if I feel so inclined (HVAC controls, gear indicator). Plus, I'm sure I could find a way to modify colors. And no fogs or asr, so I'm good there. Thanks.
F'n1996Z28SS
08-23-2023 11:19 PM
