GREAT upgrade for those crappy headlights!! (photos w/ in)
#137
Originally posted by Coolformula
my headlights suck on my firebird. can i do anything.....
Mike G.
#138
Also, somebody that emailed me for help with the Hella 90mm units mounted the lights in the round openings where the fog lights usually are, but that's a pretty low place to put them...
Sam
#140
Originally posted by Team Untouchable
Finally pics of mine almost done. I need to do the highs this week but this is the custom plate we had to make.
http://www.ls1camaro.net/freehosting/hella1.JPG
http://www.ls1camaro.net/freehosting/hella2.JPG
http://www.ls1camaro.net/freehosting/hella3.JPG
Now any better tips on aiming them? They seem to be aimed WAY too high. I try screwing the screws and the screws seem to pop out.
One more pic, this is what we had to do to get to the lites.
http://www.ls1camaro.net/freehosting/nobumper.JPG
Cant wait to take the bumper off again to do the highs.
#142
The hella light bulbs are nice, but personally I'd recommend going with simple Slyvania SilverStars in the stock housing. I bought two SilverStar low beams (C'mon now, who REALLY needs to make their high beams any brighter..?) and one stock housing. The extra stock housing I twisted the old bulb out of, siliconed the opening, and stuck the SilverStar into the hole. Taped it up and let it sit 24 hours so it can fully cure (hence why I bought the extra, didn't want to be driving around with one headlight for 24 hours), put the bulb in and repeated the process. If you buy an extra stock housing, it should cost you no more than $75. If you DON'T buy the stock housing, all it costs is $40. None the less, to replace TWO low beams it's cheaper to buy high quality SilverStars that's backed by a company that's been around forever. Two stock housings at AutoZone here in MI would cost $50, compared to two brighter SilverStars for $40.
Here's the final result of the two SilverStar bulbs, they light the road up dramatically better than the stock bulbs.
here's the passenger side light with stock housing in it. Note the yellow hue, and how brought the rest of the garage is...
here's the driver side (the one I did first) with the SilverStars. Note the entirely white light coming out of the bulb, as well as the fact that the camera had so much light given off from the bulb that the rest of the garage looks pitch black.
#146
Originally posted by AW/whiteZ-28
What do you guys think about hella 90mm's but low beams with stock high's?
I'm not doing this anytime soon just wanted your perspectives on it
Sam
#148
Any ideas on what fog setup would go well with the Hella 90mm's? (already installed)
Currently I have the stock fog lenses with 9006 style 80 watt bulbs 'custom' installed. Not too happy with the scatter.
I was wondering if FF75 or FF50 would be a better match.
Any install writeups on those FF's for fog use?
TIA
Mike G.
TIA
Mike G.
#149
TIA
Mike G.
TIA
Mike G.
Sam
#150
Who's gonna be the first to do this?
http://www.rallylights.com/hella/90m...20Beam%20Lamps
Apologize if someone already has, just noticed them.
Mike G.
Mike G.
