GREAT upgrade for those crappy headlights!! (photos w/ in)
Old 12-12-2005, 01:21 PM
  #256
NOVA5's Avatar
Re: GREAT upgrade for those crappy headlights!! (photos w/ in)
Is called.. ready?
A Dead Thread! Done, Finieto, Toast!
NOVA5 is offline
Old 12-13-2005, 12:59 PM
  #257
94BlackBowtie's Avatar
Originally Posted by NOVA5
Is called.. ready?
Umm, no.
A thread that covers that much ground shall not be determined dead unless there is a good reason.
It answers WAY too many questions on this.
So no...It is not a dead thread. It has a lot longer pauses between postings than a month in there. It just needs to be resurrected every so often.
94BlackBowtie is offline
Old 12-13-2005, 09:09 PM
  #258
Sam95ZNoTop's Avatar
Thumbs up Re: GREAT upgrade for those crappy headlights!! (photos w/ in)
Originally Posted by 94BlackBowtie
Umm, no.
Agree. I try to check every month or so and post a "keep alive" message.
Sam
Sam95ZNoTop is offline
Old 12-16-2005, 05:26 PM
  #259
Cerwin Vega Fan's Avatar
How bright are the projectors compared to say silverstars?
Cerwin Vega Fan is offline
Old 12-19-2005, 03:18 PM
  #260
PediDr2's Avatar
Hard to compare but a little brighter and much better beam pattern (less scatter and sharper cutoff).
PediDr2 is offline
Old 06-08-2006, 06:29 PM
  #261
Keep it alive Post
Sam
Old 06-09-2006, 10:37 PM
  #262
Bud M's Avatar
Here's how ya do it using the mounting plates:
1. Get the lights, mounting plates and some angle aluminum. You can also get connectors with pigtails and make up a set of plugs that will plug into the wiring harness and hella lamps so it all just plugs together with no modifying any wiring on the car.
2. Make up a bracket to attach the plate to the plastic headlight mounting assembly on the car. It may be necessary to remove some material from the car body to make your bracket fit. Assemble the brackets and plates and test fit, removing material where necessary for clearance. It will probably be necessary to reshape the tops of the plates to clear the underside of the hood.
3. Make up lamp assemblies with the brackets and plates. Installing the lamp adjusters into the plates is tricky. The easiest way I found was to use zip ties to compress the plastic adjuster (with the adjuster screw already in it) before trying to insert it into the plate. Do not install adjusters until you are certain that you will have no reason to remove them. I don't think you can get them out without destroying them. Notice that I shortened the adjuster screws for clearance instead of removing more of the plastic piece on the car than was necessary.
4. Attach assemblies to plastic with screws and nuts. (I recommend nylon locknuts wherever possible.) This will require removing some material from the top and back of the plastic for clearance and from the metal crossmember for clearance on the low beams which are deeper than the highbeams.
5. Using aluminum angle and 1/4" i.d. tubing, make an upper brace to make the entire mounting assembly rigid. Attach the bracket to the underside of the frame crossmember and run 6 mm screws through the tubing to fasten the brackets in place. Use thick enough (1/8" will work) aluminum so you can tap it so no nuts are needed. Notice that the low beams need an extra hole drilled in the plate to offset the top brace because the lamp has a part that blocks the top center hole on the plate.
Be prepared for lots of trial and error in fitting the lamps. You will need to pull the airdam and splash panels to get access to the under side of the plastic panel and wiring.
A dremel and/or air grinder is very useful for removing plastic where necessary. The dremel also does a nice job of shortening the lamp adjusters.
A small bandsaw makes working with the aluminum a snap, and you will need a drill and a few files to make your parts look professional.
The long screws for the top braces came from Mcmaster.com. 6mm x 100 mm if I remember right. I recommend stainless fasteners, or you'll get rust.
Its sort of a lengthy project if you are feeling your way through it, but its fun work and you'll be very happy with the results.
Disclaimer: Before you do this project, swap out the stock driving lights with FF75s. Much easier project, and you may just find it makes enough light for your needs.
Bud M is offline
Old 06-10-2006, 12:34 PM
  #263
PediDr2's Avatar
Nice write up.
Any chance of posting the dimensions on the mounting plates so I can fab up my own?
One of my adjuster screws has come loose and I think it will eventually fail.
PediDr2 is offline
Old 06-10-2006, 12:41 PM
  #264
Bud M's Avatar
Material is 1 x 1" angle aluminum 1/8" thick, cut to about 5 1/2" long. You can find it at Home Depot.
Bud M is offline
Old 06-11-2006, 11:57 AM
  #265
PediDr2's Avatar
And what are the dimensions/specs on the other piece pictured?
PediDr2 is offline
Old 06-12-2006, 10:12 AM
  #266
CALL911's Avatar
If you could figure a way to have this done to the LT1 Camaro's, you'd be one rich dude! I would buy them instantly! I like the way these round lights in this whole thread put out light, I just don't care for their actual appearance in the place of the stock ones. However if there was an actual replacement that went in like your listed pics, or even ones similar to a 4th Generation Supra headlamp, that would be exactly what I am looking for (and I am sure a few thousand other F-body owners as well) Keep us updated if this could be a possibility.
If anyone else out there could make this happen, please let me know, I would be VERY interested!
CALL911 is offline
Old 06-12-2006, 10:18 AM
  #267
CALL911's Avatar
If someone could make a headlamp like this to fit the round bulbs/lenses in, into the space of an LT1 Camaro, they would not only become my hero, but would also make a LOT of money.
CALL911 is offline
Old 06-12-2006, 04:54 PM
  #268
Honda Hunter's Avatar
Honestly I dont think that's really that hard to make by a pro just somebody has to step up with the cash, time and patience. I wish somebody on the board with talent could draw up a prototype. Once my car is out of the shop I have big plans for some custom stuff headlights included unless I say screw it and convert to 98+
Honda Hunter is offline
Old 06-12-2006, 09:13 PM
  #269
thesoundandthefury's Avatar
Just ordered supplies today. Gonna try for a molded fiberglass surround with Halo's integrated into it. I'll keep everyone posted on what I come up with.
thesoundandthefury is offline
Old 06-13-2006, 09:29 AM
  #270
CALL911's Avatar
Outstanding! Are you planning on using the same lights/lenses as posted in this thread (the bright and clear ones with defining lines at night)?. When do you think you would have the prototype done?
For the over all headlight lamp that everything goes in, you may want to consider a previosly designed setup that might work with some fabrication into the space (ex. GTO headlamps)
CALL911 is offline
Quick Reply: GREAT upgrade for those crappy headlights!! (photos w/ in)
