Help with install of body kit
ok got my wings west w-type kit and it says use double sided 3m tape to apply WTF>!>!
Ok i want it to hold, any other suggestions...could i bondo the lip or would it make it look to wavy???
Re: Help with install of body kit
If its just the ground effects use the tape and some screws to hold it in place. Run the screws through the lip that connects to the car fender wells. This is pretty much all I used when I had mine on. On the front run screws all the way around, once you place the piece up to the nose you'll see an over lapping part up under the nose. Hope this helps. I didn't install min the body shop did, but as far as I can remember thats the only place they screw it in and I never had any trouble.
Originally Posted by hondah8ter
message deleted
As for the bodykit, you can either use tape, tape with screws, or just screws. I have the WW F-1 OEM bodykit (front and sides, rear piece is different) and I have it held on 100% with screws, I didn't use tape at all because I didn't want the tape to show. My rear piece is a Vizage / Stella rear bodykit piece, and i used tape on that with screws. It works, but you can see the tape.
thanx for the help, i am gonna screw and tape it together, hopefully it doesn't show but if it does i guess it will be time to get the old razorblade out.
Originally Posted by meissenation
You're an idiot. Quit being a troll, post something helpful or stfu and don't post at all.
then he wonders why nobody replies in his thread about wheels/springs.
keep burnin those bridges!
Unfortunately, hondah8ter seems to spend most of his time here trashing the other members for having ideas that are a bit different than his. His posts of that ilk will simply be deleted, and if he continues, he will be banned. His actions have already been noticed by Brent and JasonD, and he has been warned.
i used some self taping screws and counter sunk the wholes enough so the screw didt show then i molded the whole kit in. took a total of 3 days and 2 cases of bud light and a gallon of bondo to finish the whole thing
CARiD
01-14-2015 04:00 AM
CARiD
12-26-2014 04:20 AM
