How do I fix this?
How do I fix this?
The picture below is one of the only visual problms with the car I just bought. The strip on the door where the fener and the driver's side door meet is coming off. Can I just use epoxy(sp?) or something like that to get this to stick?
http://www14.brinkster.com/tomsim/
I just took mine off it looks alot better IMO
but some weather strip adhesive will do the trick you can get it from any autoparts store also make sure you clear the surface from exsiting residue
I took my molding off also. Looks cleaner, washing the car is easier and so is waxing. Do a search on removing the side molding and you will turn up some pictures to get and idea. You won't regret removing it.
