how to drop camaro with mac springs
Get a 6 pack...
'Cause it could take a while. All that is totally necessary is a spring compressor and basic sockets and ratchet. There are no real hints I could give you, but it wouldnt kill you to pick up a haynes manual. Look on brents page for some links. I know there's one thats pretty helpful, because I used it for guidance. Also try posting this in tech, much more help over there.
Take out the whole front spring/shock/a-arm assembly. It makes it much easier to work with and be safe with the spring. Just compress the spring and unbolt the shock mount then pull it off. Take it the spring/shock/a-arm assembly to a shop if you feel unsafe with compressing it.
Originally posted by stik6shift98
no....do i need that
12-01-2014 08:08 AM
