How hard to remove front bumper cover on 93 to 97?
Also, for those of you that have replaced fenders, how did you get the bolt that goes on the inside of the fender on that 1 bracket in? It seems like it'd be impossible to do while you're trying to put the fender on.
Right where the fender bolts to the nose there's 2 nuts and 1 bolt. Then there is one small bolt under each headlight that have to be taken out from underneth. The rest of them are all in plain view and pretty easy to get out. When you put it back on just make sure your get all the clips back where they need to go.
Hope this helps.
Mike
Hope this helps.
Mike
heavenly_six
12-10-2014 12:23 AM
