Hvac
Old 05-11-2003 | 12:25 PM
blackz151's Avatar
Hvac
how the hell do i get the HAvc outta there so i can change the bulb to LEd?
Old 05-12-2003 | 11:05 AM
trax's Avatar
If you do a search in the LT1 Tech section you can find a guide that I made. But here are the steps that are most important for you:
1. Remove A-pillar panels
2. Remove the wide black plastic panel near the windshield
3. Remove the knee bolster under the steering wheel
4. Remove the panel surrounding the stereo head unit (you may need to open your glove box to get at all the screws)
5. Unscrew the plastic shroud over the instrument cluster. Pull it out by somersaulting it over the steering wheel (that statement will make sense once you get to this step).
Good luck... PM me if you have any questions.
Old 05-12-2003 | 03:06 PM
iamsparc's Avatar
When I started attacking stuff like that...I just started unscrewing things until I finally got to what I wanted. It's fairly self explanatory once you have that screwdriver in hand and start going at it.
-Mike
cmsmith
09-14-2015 09:25 PM
trax
10-05-2004 10:52 PM
c0rey
12-22-2003 03:44 PM
95droptopZ
04-26-2003 10:13 AM
ReznorZ28
08-28-2002 10:02 AM
Quick Reply: Hvac
