Instructions for replacing bumper lights?
I bought some nice new bumper lights for my f body, but dont know exactly how to replace them. do I have to take off the whole front bumper to put them in or is there an easier way?
no you don't have to remove the bumper, i have also installed a set of clear turn signals but it is sort of a pain, Do it from under, It's easiest to take all the black plastic underneath off including the air duct, the hardest part is getting the old lights out, I put a 3/4" crack in my bumper doing it so be gentle even though that is hard to do. I can't remeber if they are bolted in or if they just snap in. It's defintly worth the trouble though, thet look great.
This was on my 2000 camaro, yours might fastened in different, it might be easier.
Re: Instructions for replacing bumper lights?
This was easy, I thought I'd update for future reference. I removed the bottom left and right plastic's BLACK with about 12 screws and also removed the air dam which kind of ties into those corner plastics... all in all like maybe 20 screws 2 different socket sizes and once I removed the old light I needed to remove the CLIP from the old light that the bottom screw mounts to and place it on the new light. It has a bent retainer so just bend it up and it will slide right off... 3 screws on each light.... then push up on the light to remove...
wasn't hard.. found my K&N air filter laying in the bottom once again? I swear either these suck or nobody knows how to mount them... I mounted it this time and it's solid, did it before replacing the plastics!
And I never expected the lights to as big as they are... they 'HIDE' behind the fascia/bumper!
To the OP, this doesnt work on the earlier models, and from what a friend of mine told me, going in from the bottom actually is your best bet. just be careful, and best of luck!
10-31-2016 11:09 AM
isimplyexist
03-25-2004 08:06 PM
