Just finished Red LED gauges
#16
so id have to say no abuot the glows....lol i understand. it was iffy in the first place.
i feel old here. shoot i already forgot what they used to be? i wanna say black backround lighting up in white. but it has been almost a year since i have seen the normal gauges. before i switched to these led's i had some indiglo's, so sorry if thats not right
#17
Camaro gauges have a blue plastic behind the numbers so they would light up more white with regular bulbs so when I put in hyper white instead of being more white they became more of a blue.
In your formula or T/A it has red plastic behind the numbers so it lights up red so your stuck with red sorry unless you wanna either get blue bulbs and make it purple or find out how to switch over to a camaro gauge cluster to get blue or you could get some reverse indiglo's
#19
Originally posted by jare23
yea i came to the conclusion that this digi is my new paper weight. but to answer your question, they are much brighter. but im still trying to see how to make my HVAC and light indicator light up red. havent looked into that much but wanting to do so in the future.
Then
Peel off the Hvac overlay and the headlight overlay so you can see the backside , take the red film from the double sided tape and cover areas that light up white . After you peel off the overlays there enuff adhesive on them , the red film will stick where you want it and still have enuff left to re-install them . The backing is sticky as hell . It will then light up bright red and not look dim .
#20
Originally posted by MikeStank
are you sure on that there is red behind the numbers??
http://www.macewenmotorsports.com/howmabudoine.html
#21
On the guage faces for PONTIAC , the red is actually impregnated into the plastic face , PLUS it is silkscreened on back with a layer of red and thin layer of white
Camaro faces just have the light blue silkscreen with a thin layer of white over that .
#23
so the only way to do it is to buy a new overlay which replaces the factory.. I know i've seen this somwhere, and it actually lights blue. Or can it be removed with some skill
#29
Originally posted by 90 Z28SS
Go buy some 3M clear double sided tape . The backing on that is a translucent bright red , very thin and peels right off .
Then
Then
#30
sorry if im the only one who doesnt understand this...but what the h*** does that mean???
I'm looking at pure black pictures with faint specks of red light. Kinda like deep sea fish might see just before being eaten...
10-31-2016 11:09 AM
99TransAmWS6
02-12-2015 07:23 PM
