Looking gor mesh material????
Guest
Posts: n/a
BINGO - i knew i couldn't have been the only one to ever to this- yes thats exactly what i want- i have a ss steel type wire mesh i'm using - but don't like it- your is what i want and i also have a hard time getting it to stay tight in the holes. please tell me all the info- material- where to get it- and how do you install it?
thanks- you can also email me at flusz@aol.com
Well, I hate to tell you this, but you're out of luck.
Those grilles - I made - and they are gutter guard, from Lowes.
So, if you don't want gutter guard - you are pretty much SOL.
Other than that - when you do finally find the right material - I'll just go ahead and forewarn you - it's a pain in the butt to make them.
I posted those pictures here about three months after making that one grille - because off and on for about three months I would work on it trying to get it to look better.
The best way I found was to cut you a template out of some pretty thick wood, and sand the edges until it fit perfectly into the opening - then mold your mesh around it. It is by NO means easy. And the stuff is very hard to shape around the edges.
As far as holding it on - picked up some "Extreme Velcro" also at Lowes. Silver in color - so it at least matched the mesh.
Now - if you want to know what the best way to do this would be - Get you a front clip or take your off - turn it up, and make you some molds out of plaster of paris or something in the openings, and bend the grilles.
Good Luck.
Good Luck.
Guest
Posts: n/a
well yours looked pretty good and it didn't look so dull like gutter gaurd does- anyhow i will just keep looking for something. i guess you pretty much gave up on installing/making them fr your car? the ss steal material that i have installed into there right now i made it fit pretty well- i will have to find something and just play around with it.
thanks
thanks
CARiD
09-30-2015 05:44 AM
mlopezart
09-08-2015 12:15 PM
08-17-2015 09:50 AM
