LT1 Intake Manifold
LT1 Intake Manifold
I am cleaning it up with a wire wheel on my hand drill. It has a rough looking but high luster look to it, and it looks sweet. What can I use to seal it up? Like Clear Coat? Thanks guys
A high temp clear powdercoat would be the best way to go. There's also a product out there called Zoop or something like that. It supposedly seals the aluminum and keeps it from oxidizing but the stuff aint cheap. I'd just go with a clear powdercoat, that's what I've done over the past few years and the stuff I've had coated is still looking great.
-Mindgame
-Mindgame
Yes, any place that does powdercoating is going to have the stuff to do this. There's is quite a bit of engine block powdercoating going on these days so it's nothing out of the norm as far as the temps go.
You're probably looking at $30-50 for an intake.... at least those are the prices I'm seeing around my area.
-Mindgame
-Mindgame
-Mindgame
-Mindgame
someone on ebay is porting and polishing with any colored coat for 80 plus shipping to and from. not bad, around this area, it'd be a hundred bucks just to port. he ports to 58mm and cleans up the inside a bit.
ModdedNerd
12-14-2014 10:28 AM
07-04-2005 05:00 PM
