The outer polymer body is starting to peel away- HELP!
The outer polymer body is starting to peel away on the drivers side door. Does any recommend a certain brand of epoxy to fix it?
thanks in advance:-D
ah, the seperating door...
most likely you have a 93-95 right? its a fairly common problem. GM used an inferior adhesive hence the problem you now have. i have fixed this several times and JB Weld seems to be the best bet. Make sure you clean the 2 panels as well as possible, remove ALL dust or debri, apply JB (with window down) and clamp the door. let it sit as long as possible (no less than 12 hrs) then unclamp, sand off any extra, and you should be good to go...
BandDirector Blk98ZM6
02-20-2015 07:42 AM
1996LT1Z28
Middle Atlantic
12-04-2014 09:37 PM
1996LT1Z28
12-04-2014 09:20 PM
