OZ Rims and Tire/Wheels Fitting
Will not fit at all..... wrong bolt circle. You need 5-4.75" (5-120.65mm).
Other problem is the "frontspace" will be about 4.32", which means they will move out from under the fenders by about 1", compared to the OZ Monte Carlos shown in this picture. Those are 17x9.5 w/ 49mm offset. For an 8.5" wide wheel, you don't want less than about a 35mm offset. The stock 8" and 9" wide wheels are 55mm offset. As the offset drops, the wheels move out from under the fenders.
04-03-2015 10:54 AM
mschmidt33
03-15-2015 07:20 PM
BandDirector Blk98ZM6
02-20-2015 07:42 AM
