Procarparts.com guage overlays and clear marker lights any good?
I was gonna order the reverse indiglo guages and the clear marker lgihts from procarpparts, but i wanted opinions on them first. do the gauges work well? does the lighting flicker or burn out quick. and do the clear marker lights for LT1 firebirds/transams leak alot or anything like that?
any help is much appreciated!
i've had the procarparts clear turns signals for over a year now w/o any problems. no leaks or fogging up. like ArcticYT95TA, i also got the incorrect amber bulbs. i went to the auto store and got super white bulbs anyway.
i installed the lights from under the car w/o jacking it up (kinda hard on a lowered car). took about 1.5 hours total. when i changed the bulbs a couple days later i realized i was able to reach my arm under the headlights after manually popping them up. you can't see what you're doing, but if you look before you reach in there you can feel around for the bolts.
10-31-2016 11:09 AM
2000silverz28
07-20-2002 06:14 AM
