racing seat belt install help
Old 07-10-2013 | 09:32 AM
jmill103's Avatar
Can you install a 4 pt racing harness with out having a mounting bar? Can you just bolt them to the seat brackets?
Old 07-14-2013 | 10:44 AM
Re: racing seat belt install help
NHRA tech requires that the shoulder harness strap attachment points must be level with the shoulders, to no more than 4" below the shoulders. I believe the reasoning it that in a crash, near vertical shoulder straps (e.g. attached to the floor) will place your spine in compression. Note also that many "racing harnesses" are not USDOT approved and are not legal replacements for factory belts, for street use.
I've had the floor area around the bolts that hold the seat brackets to the floor crack and let the bolts move around. That area is definitely not strong enough to anchor any part of the harness.
RUDEDOG
Parts Wanted
04-24-2015 09:47 PM
alphaauto
01-23-2015 07:42 AM
Joes96z
12-14-2014 04:03 PM
siguy
11-27-2014 10:07 AM
Snoman73
11-17-2014 07:22 PM
Quick Reply: racing seat belt install help
